Community Member
RDP is stopping Unity
When we try to RDP to our primary unity server from our desks the connection stops users from getting to their unity messages. If a user hits the message button it tries to intialize the call but then just drops it. Any ideas? Thanks in advance.
1 ACCEPTED SOLUTION
Silver
Re: RDP is stopping Unity
I usually disable Terminal services and just go with VNC. That can be resource (CPU) intensive on a busy server.
Best thing is an IP KVM, but usually expensive.
There is HP's ILO, but you have to purchase a license for graphical mode. Don't know how much that is. Haven't used it since the Novell days when you had to purchase a separate EISA board.
Most of your web page administration should be coming from HTTP from your PC. I see people VNC or RDP into a server then launch the browser from there. Try not to do this. But you sometimes have to because of all the "Stuff" on people's PC don't let the web pages work correctly. Especially JAVA.
Community Member
Worked perfect. Rob, I should just take down your work email since you seem to be answering all my questions.
Hall of Fame Super Red
Hi Efrain,
Glad to be of some small help here :) You will find many answers here from many helpful people. I'm just happy to be part of things!
Take care,
Rob
119
