Re: Cisco 7912 Firmware download
Jose Robles
Does anyone have access to download  the lastest firmware for the Cisco 7912 phone. I have a Cisco cucm 4.2 (3) environment and will be upgrading to 7.1.5 however I would like to update the firmware first
cm-7912G-sccp.8-0-4.exe
Thank You
Jose Robles
This is the image I need
cmterm-7912G-sccp.8-0-4.exe
The file is available on CCO, just search for that filename and you'll get it.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
