Re: CME 4.1 Authoring outbound callers to pstn
How does CME permit authorize users to make out bound calls to the PSTN and prevent un authorize users?
How is this feature setup?
Hall of Fame Super Gold
Re: Re: CME 4.1 Authoring outbound callers to pstn
You have three methods:
1 - COR list. Permanently block certain calls from certain phones and cannot be overridden.
2 - PIN login & after-hours. Once logged with a per-phone pin in you can dial certain patters and also define a time schedule for this to happen.
3 - Custom steering digits. You create special prefixes to allow certain calls and this code is given to people, kind of like an account number.
1 & 2 are explained in the sysadm guide and others CCO documents. 3 - is not but easy to figure out.
Thanks for your help
Can you outline the steps required to do the Pin Log in & After hours?
Do you have a sample config?
As I mentioned the documentation has outlined steps as well examples:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a008080d9ad.html#wp1011535
As a courtesy to those providing answers,please rate all useful posts!
Thank you
95
