Community Member
RE: MCS and UCS servers in a cluster
I have a customer that has a cluster of three MCS Servers (one Publisher and two Subscribers). They want to expand the IPT solution by
extending to a new location, but still in the same cluster.
I know I can place a new MCS Server at the new location to act as Subscriber 3, but is it also possible to use a UCS server (especially BE6k server) at the new location?
That is, can we have a combination of MCS and UCS servers in one cluster?
Also, are MCS servers still orederable from Cisco?
Note that relocating one subscriber from the old to new office is not an option for the customer.
I will appreciate prompt answers.
Peter.
1 ACCEPTED SOLUTION
OK, so, the only problem I see here, is that you want to use a 6K in the mix, the 6K is limited in the number of users/devices you can have, as well as the OVAs you can use on it. If you have a 6K in the mix and the rest are MCSs, TRCs/spec based or 3rd party spec based, that's fine, but then, that 6K needs to hold the PUB.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
You can have a mixed environment but its not recommended. In regards to the MCS servers, they're end of sale.
http://www.cisco.com/c/en/us/products/collateral/unified-communications/7800-series-media-convergence-servers/end_of_life_notice_c51-699263.html
Yosh
HTH Regards, Yosh
Purple
Hi Peter,
In addition to what Yosh[+5] has said,from CUCM version 10 onwards, only virtualisation is supported.
regds,
aman
java
java
125
