Re-route the call
chingkiatlee
Anyone have any idea how to reroute the PSTN call from 1 cluster to another cluster's vg (MGCP)?
Phone A registered to Cluster A.
VG B registered to Cluster B via MGCP.
Cluster A & Cluster B is running as intercluster trunk without Gatekeeper.
Is it possible the phone A make the PSTN call via Cluster B's VG?
thank you.
Chris Deren
Sure, simply build route pattern pointing to the ICT and then on the other cluster ensure the CSS assigned to the trunk has access to the GW via either direct access to outbound RPs or intermediate translation patterns.
HTH,
Chris
Chris Deren
HTH,
Chris
Jaime Valencia
Yes, just make sure whatever you're sending via the ICT is routable in cluster B and that the inbound CSS from ICT on B has the CSS that allows for outbound calls.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
