Read/Get SNMP from Cisco phones
Is there a way to read/get snmp information from cisco phones? I have snmp enabled on the call manager and subscriber, but can't find a way to read snmp info from the phones. Is that possible? Thanks.
Re: Read/Get SNMP from Cisco phones
Nope, no MIBs are available for actual phones.
david
The following is configuration to be done for getting the SNMP traps for Phones, as per CUCM manual:
Configuring CISCO-CCM-MIB Trap Parameters
Unified CM and Unified CM BE only:
Use these guidelines to configure CISCO-CCM-MIB trap settings on your system:
Set ccmPhoneFailedAlarmInterval (1.3.6.1.4.1. 9.9.156.1.9.2 to a value in the range 30-3600 by using the SNMP Set operation; for example, use the net-snmp set utility to set this OID value from the linux command line using: snmpset -c
-v2c
1.3.6.1.4.1.9.9.156.1.9.2 .0 i
You can also use any other SNMP management application for the SNMP Set operation.
Set ccmPhoneStatusUpdateAlarmInterval (1.3.6.1.4.1.9.9.156.1.9.4) to a value in the range 30-3600 by using the SNMP Set operation; for example, use the net-snmp set utility to set this OID value from the linux command line using:
snmpset -c
-v2c
1.3.6.1.4.1.9.9.156.1.9.4.0 i
But can someone help me in getting the Linux CLI prompt in CUCM, as these commands are to given on Linux CLI, or is there a mistake in my understanding.
477
