Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Real Time Monitor Warnings
Hi All,
I am getting the following error with Real Time Monitor.
LogPartitionLowWaterMarkExceeded UsedDiskSpace : 90 MessageString : Disk utilization hits LWM! AppID : Cisco Log Partition Monitoring Tool ClusterID : NodeID : CM-PUBK
Any idea on how to fix it ?
I found this information about the error:
CCM_TCT-LPMTCT-3-LogPartitionLowWaterMarkExceeded : The percentage of used disk space in the log partition has exceeded the configured low water mark. UsedDiskSpace [String] MessageString [Optional]. [String]
Explanation The percentage of used disk space in the log partition has exceeded the configured low water mark. There is no files to be purged under such a situation.
Recommended Action Check if the configured low water mark for used disk space in the log partition is too low. And also please examine each application trace log files and clean up those that are too old and too bbig before the used disk space exceeds the high water mark.
But it does not show how to clear out the logs.
any help would be appreciated!
Re: Real Time Monitor Warnings
What version of CCM are you running, in version 4.x, the watermark is set to 20% which can be increased in Enterprise Manager. Settings are a bit different in CCM 5.x/6.x
We are running version
6.1.1.2000-3
in the real time monitor the level is set to 90
I think I have seen this before and its a known bug in the version of CUCM, there are some .pdf files for CAR that gets populated which donot get deleted automatically and occupies disk space. I would recommend to open up a TAC case.
thanks,
we'll open one up
1542
