09-13-2017 03:31 PM - edited 03-17-2019 11:10 AM
Hi there
I´m not really sure if I need CUBE configuration, we are going to connect via sip trunk to another site (another voice network), I already know their ip address where I set up in the sip trunk, as you might know we are going the use the TCP port 5060 which is the default.
As you might know signiling and RTP´s do not pass throught the same sip trunk, and as long as I know they travel separately. (correct me if I´m wrong)
So, the security team have told me that they cannot open ports for the RTP´s, so my voice team thought to configure CUBE for the RTP´s. So my question is, if we are correct or if there´s another solution? Let me know if you guys have questions. thanks.
09-13-2017 06:55 PM - edited 09-13-2017 06:56 PM
May I ask how the two sites are getting connected? In terms of the layer 1 of the OSI Model.
09-14-2017 07:03 AM
Well
In terms of layer 1, let me doble check that, why would you like to know about conectiviy for layer 1?
This is how we are planing to connect.
- the other site will be able to connect from their public IP address to us T1 Prod public IP X.X.X.X over TCP port 5060.
- that ip address translates to our cucm
- For outbound connectivity we will create the SIP trunk to communicate to the other site over TCP port 5060.
- These outbound connections go to the Internet via Shared Services.
- When these connections go out, they will be translated to one of 4 ip address that will have.
So basically I will only need to create the SIP trunk, but I know will only pass the signaling and I´m concern about the RTP´s. thanks.
09-13-2017 06:59 PM
09-14-2017 07:04 AM
I wish but, but let me explain you, how is going to be:
09-14-2017 09:09 AM
Hi Israel,
I would not expose the CUCM to the Internet.
The CUBE is the best solution even because you would expose its public interface only (behind a firewall opening signaling and rtp ports) .
You could apply security restriction on the CUBE by allowing connetions by remote public and local internal IPs only.
Carlo
