Reboot History
This morning I discovered that one of my UCM-7 Subscribers was off-line. How can I find out when it shut down / was turned off? If it was M$ I'd just look at the event logs. For Linux I'd look at the /var/log directory. Unfortunately I can't seem to be able to do that. I also don't see anything in the reports, serviceability, or OS admin to point me in the right direction. Is it possible to get a report? If so how? Thanks. Lee
1 ACCEPTED SOLUTION
Re: Reboot History
The app logs and related info are only accesible via RTMT, not directly via CLI. Gather them via RTMT and they might provide some info on what happened.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Re: Reboot History
java
java
Re: Reboot History
Thanks. Found the reason. Overtemp forced shutdown.
226
