06-27-2007 07:21 PM - edited 03-14-2019 10:18 PM
We keep on getting power failures at our location. Which one should be powered on first?
06-27-2007 07:26 PM
there is no specific order in which you got to do this, but it would make sense to power them on both at same time or atleast callmanager first (either ways nothing big is going to happen). No sense in Unity being up without Callmanager being up and running
06-27-2007 11:57 PM
I agree with hanky...
there isn't any order, just remember to check that the voiceports are registered after both are up.
06-28-2007 01:59 PM
problem is when I power Unity back up, and then CM, voice ports are not registergin. So I figured CM first and then Unity?
06-29-2007 05:18 AM
Sure, go ahead.
What TSP version, CM versiona and Unity version are you using ?
Does the ports show unregistered in callmanager or do they show up with an 169.x.x.x address ?
