Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
rebooting all 7941s
Hi experts,
Is there a way to reboot thru Call Manager or other to reboot only those 7941 phones? We just upgraded the firmware.
Tnx
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: rebooting all 7941s
Hi Robert,
Sure, via ccmadmin if you go to Device>Phone>Search by Device Type>7941 and all the 7941's will be available (check 50 per page). Then Select-All checkbox and reset. You just go page by page and reset all 50.
Hope this helps!
Rob
Hi Robert,
Hope this helps!
Rob
In addition to the solution Rob gave you, you might want to use BAT if you want to reboot an hugh amount of Phones (Update Phones -> search by Device Type -> select "reset phones" -> press update).
Remember though that the Communications Manager (CallManager) throttles the number of TFTP requests to control/reduce the load.
Eric
110
