Community Member
rebooting CCM 6.0.1
I am running CCM 6.0.1 and need to reboot it.
CAn I just putty into it and issue a "shutdown -r now"
Or is there a certain proceedure I need to do because its Cisco and Linux?
I attempted to search Cisco.com but didnt find anything. If someone can post a link to a doc that would be great
Re: rebooting CCM 6.0.1
there is already documentation for that:
utils system
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/6_0_1/cucos/iptpappa.html#wp1051058
Command Syntax
utils system {restart | shutdown | switch-version}
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
thank you
that was the doc i was looking for
135
