05-18-2008 01:45 AM - edited 03-15-2019 10:43 AM
Hi, I got a problem.
My customer use callmanager 6.1 and ip phone 7941,3845 Voice Gateway use E1 PRI connect to 2 PSTN Provider CHT by 4 E1 and MKY by 1 E1.
When user call out to PSTN phone by CHT if the called phone is talking to someone then CHT will reply busy tone to 7941 so caller can hear busy tone that is fine, but if call out to PSTN phone by MKY, it just reply busy signal not busy tone so 7941 cann't hear any sound.
How to setup IPT when receive busy signal then play busy tone to 7914?
05-18-2008 01:48 AM
You need to specify if you are using H.323 or MGCP as a protocol.
05-18-2008 05:02 PM
I am using MGCP..
How to specify..?
06-19-2008 08:09 AM
Did you find a resolution to this? I have a customer who has an h323 gateway and is getting the cisco "call cannot be completed message" when they would like to get the busy tone.
09-08-2008 02:14 AM
Did you get an answer for this. I got the same problem
09-08-2008 04:46 AM
Yes, It happened to be that I had a second gateway in my route group and that gateway was not configured right for centrex lines.
