Community Member
Receiving VM while VM is set as no VoiceMail
I have a CUCM 8.6 with a Cisco Unity, some users have under DN/VoiceMail: "No Voicemail", but still they are receiving Voicemail from some external calls, if we try to simulate the problem we cant.
And we can't remove the users extensions from Cisco Unity so that the extensions can still be reached from the AutoAttendant.
1 ACCEPTED SOLUTION
If they can be reached in Unity and you're allowing users to leave a message after the greeting, they can get VM, no workaorund for that.
Re-configure so they cannot take messages in Unity after the greeting.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
1 REPLY
java
java
104
