Recommended Settings for NIC cards on call managers
Hello there,
What is the Cisco recommendation for setting port speed on the servers.
I know on older servers that were 100 meg nic cards, you hard coded as 100meg full duplex on the call manager as well as the switchport
what is the official stance on the new 1gig server NIC, since you can't hardcode 1000 on an IOS. (unless i am missing something)
thanks!
Re: Recommended Settings for NIC cards on call managers
See the link below which says:
"For 1000 Mbps, Cisco recommends using Auto/Auto for speed and duplex configuration on both the NIC and the switch port."
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/callpros.html
Hope this helps. If so, please rate the post.
Brandon
thanks!
I thought thats what it was but couldn't find the link you had.
We are having some weird issues that we are trying to resolve and I wanted to cross off speed/ duplex as an issue.
Bronze
I've been asked to change the NIC on my CUCM servers from auto/auto to 100 full. We had new CUCM servers installed, and they were left on auto. The switch is set to 100/full and getting mismatch errors constantly.
Can someone tell me how to change the NIC speed? 7825H3 CUCM 6.1.3
Thanks so much,
Liz
Liz,
Take a look at the following link.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080772bb9.shtml
Brandon
Bronze
Thanks Brandon,
I will try tomorrow morning as this:
"If you continue, this command causes a temporary loss of network connections while the NIC gets reset. Do you want to continue ?"
leads me to believe the phones will reset. I can't do this during business hours. Do you agree?
Your phones will not necessarily reset, but I would recommend doing this after hours.
Brandon
Bronze
Thanks again Brandon,
I don't make changes via CLI and I'm super nervous. I ran the show command and got:
admin:Auto enabled, Half, 100MB/s
I need to know what to type to change to 100/full without auto.
I've know this much:
set network nic eth0
but don't know the rest.
Can you help?
The command would be:
set network nic eth0 auto dis speed 100 duplex full
Hope this helps.
Brandon
Bronze
Thanks Brandon,
I made the changes this morning, without dropping the phones. I couldn't type the whole line, but had to do each alone. But, they took and I'm happy.
Thanks again and sorry for hijacking this tread!
249
