Recording Auto-Attendant greetings/prompt
Good day all,
I am trying to configure auto-attendant prompts.
I am recording either greeting or prompt using the AVT on the TUI. Everything is ok, I can hear it, I save it.
The problem is that...
When I call my company, I listen the recorded prompt (which is in greek) and then I listen the default (which is in english).
How can I configure it to listen only the first (that I have recorded).
Re: Recording Auto-Attendant greetings/prompt
Anybody to help with this problem???
I think you need to provide a bit more information.
What product is running Auto-attendant (Unity, Unity Connection, UCCX etc.)? - include version info.
What are you using for call control? CUCM or CUCM Express - include version info.
ok!
Call manager express 7.0 (flash:c2800nm-adventerprisek9-mz.124-20.T.bin)
Cicso Unity Express 3.1
If it is like Unity Conn, while in the AA select EDIT, then select the greeting that you want Standard, Under "CALLER HEARS" change this to my personal Greating.
Then on the same page go down to recording select Play/Record. Record a greating - or call in and record the greating.
Select Save when done.
I don t have this option
This is the conf:
ccn application autoattendant aa
description "CiscoAutoAttendant"
enabled
maxsessions 4
script "aa.aef"
parameter "dialByExtnAnytime" "true"
parameter "busOpenPrompt" "UserPrompt_05132010042326.wav"
parameter "dialByExtnAnytimeInputLength" "4"
parameter "operExtn" "110"
parameter "welcomePrompt" "UserPrompt_05132010042325.wav"
pameter "disconnectAfterMenu" "false"
parameter "dialByFirstName" "false"
parameter "busClosedPrompt" "AABusinessClosed.wav"
parameter "allowExternalTransfers" "true"
parameter "holidayPrompt" "AAHolidayPrompt.wav"
parameter "businessSchedule" "systemschedule"
parameter "MaxRetry" "3"
end application
After reading some cisco documents I found this:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/user/guide/assistant/7xcucugasstx.html
I can manage my personal greetings using the Cisco Unity Assistant.
Do you know if this is the only way to do it???
Thanks!
I use natural speaking program to create my message then upload it. we have another department that does a
"professional" Recording then we upload them, this sounds much cleaner.
I download the CUCEEditor3.1.1.exe
I make a new script and now it works, without listening the english language.
The last problem, is when recording a greeting for the VOICE MAIL first I hear that greeting and then the system prompt.
You do not have full control over the exact  content of the phrases spoken to the caller. The recorded greeting for  the GDM is played out to the caller (which you can fully control), but  that is followed by the system prompt "You may record your message at  the tone. When you are finished you can hang up, or press pound for more  options," which cannot be bypassed, suppressed, or provided in a  language other than the system language installed on Cisco Unity  Express.
I don t want to listen that prompt.
What can I do for that?
Anybody???
I've maybe found something. Try the following:
- login to CUE, on the CLI;
- go in config mode
- type the command: no voicemail conversation caller recording-prompt
Let me know ...
Cheers.
Gio.
1060
