Community Member
Recording CCM Calls
Can you advise what applications can we use for recording Cisco Call Manager calls?
Thanks.
Recording CCM Calls
you can use CallRec from zoom http://www.zoomint.com/
Anas
please rate all helpful posts
Purple
Recording CCM Calls
You can also opt for Call Recording Harmony Solution from KnoahSoft.
regds,
aman
Blue
Recording CCM Calls
What kind of recording you are looking for. We can use CUE unity express recording for small number of users. If you are looking for Contact centre environment, you can use Calabrio Product QM/WFM/CR etc...
Or Nice/Witness Recorders have been tested; Verint and other third-party vendors manufacture suitable recorders.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
145
