Recording extension calls on CUCM
Thiago Gandara
Hi voice team,
I need to record 40 extensions calls (always) there is a possibility to do this in CUCM?
if not possible, how can I do?
Thiago
There are many call recording solutions, such as:
Calabrio
Nice
Verint
CallRex, etc, etc
most of them can utilize Cisco MediaSense or use their own call recording engine.
HTH,
Chris
Jaime Valencia
No, CUCM is not a recording appliance.
You either need a dedicated recording solution, or a Contact Center solution which provides this feature.
If you search CSC, you'll find plenty of references to 3rd party products for this.
java
if this helps, please rate
You can show me a CSC example?
Calabrio
Nice
Verint
CallRex, etc, etc
HTH,
Chris
