Recording SIP phone- CUCM 8.5.1
I am setting up recording (Eventide VR-725) with a 7962. Looks like I have it using BIB.
BUT, is there a way to record a virtual SIP phone?
This is a DN on an Avtec dispatch console. It is using SIP but no actual instrument.
Is there a way I can get it to record on my Eventide?
Mark
Everyone's tags (3)
Probably not directly on the
Probably not directly on the SIP phone itself, unless it has a feature to do that. I am not familar with the Avtec application.
You could do it by SPANing the switch port to a recording server that supports span recording.
If you have a CUBE with SIP trunks you could use newer network based recording (media forking) feature on CUBE (IOS).
I can try to give it a go-
I can try to give it a go- since it is a 'virtual' phone appearing at two places but I think originating from another it may be a bit of a challenge to SPAN it (have to be an RSPAN).
I don't recall, is there a way to send only specific traffic (phone) when doing a SPAN?
The one I did before was sending everything I believe.
 (Cisco 3560X switches).
thanks
Mark
I wanted to do a followup on
I wanted to do a followup on this.
I got the Avtec SIP phones to record.
I simply have them 'audio forward' to the recorder on the proper port (assigned to channel) and they worked fine.
I thought it didn't work right before, but now that the VoIP Gateway (Eventide) is gone it is working just fine.
Mark
257
