Recording solutions for CUCM/CME.
Hi, all!
I have a questions about call recording solution for CUCM and CME.
- Does Cisco Media Sense support call recording for Call Manager Express?
- Will Media sense write all calls, including calls via PSTN to any DN, or only DN to DN calls?
- Can it be used for call recording in CUCM?
- Network-based call recording feature available only in CUCM 10 or early versions?
- What is disadvanteges and benefits of span/rspan call recording solutions?
Have you got a solution for this. have you found any recording server that will work with Cisco CME.
I am having a similar requirement. Even a 3rd party solution will work for me.
Bejoy
Hi Bejoy,
Hi Bejoy,
We(CommSouth) do offer recording solution for Cisco CME. If you are interested, please contact me at prasana@commsouth.com.
Prasana
Regards, Prasana Kumar.P +919841027006
You can use the live record option if your CME is integrated with CUE.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_1/administration/guide/voicemail/12advVM.html#wp1016471
Aseem
Hi Aseem,
Hi Aseem,
Thanks for the answer. But we are looking for a full fledged recording solution.
A network based recording
A network based recording solution would work with CME environment. One example is MiaRec.
Refer to the link below:
https://www.miarec.com/knowledge/how-record-calls-cisco-unified-communications-manager-express
For integration and version support you need to check with the vendor.
Aseem
(Please rate if useful)
Hi Bejoy,
Hi Bejoy,
Please do rate if you feel have shared you the required information.
Prasana
You can find more solutions here as well. http://www.commsouth.com/UCC-Applications.php
Yes, now Cisco Media-sense with CUBE Dial-Peer Media Forking recording supported for CME & SRTS..
CUBE ISR G2 platforms supported
   •CUCM independent
–SIP Trunk direct from CUBE to MediaSense
  •Requires both legs to be SIP
–Inbound and Outbound leg
–May need to make use of loop-around if TDM
  •Record on inbound and/or outbound dial-peer
Recording in SRST and CME
•Uses CUBE dial-peer forking
•Requires loop-around configuration in dial-peers
•CUBE requires calls to route through an inbound then outbound SIP dial-peer
•Call has to “depart” CME/SRST to record
best regards,
Naveen
1118
