10-06-2014 04:00 PM - edited 03-17-2019 12:26 AM
How Can I successfully record voice traffic going through CIsco IP COmmunicator.
Is this possible? If it is what do I need to do from the ccucm side to gateway and switch that the IP communicator is connected to all the way to my recording server what are the config needed and devices and configuration needed to accomplish
Thank you
Abdul
10-06-2014 08:55 PM
Hi Abdul,
Please check the following posts
https://supportforums.cisco.com/discussion/12076306/call-recording-cipc
https://supportforums.cisco.com/discussion/11638276/recording-and-monitoring-when-agents-us-cipc
Manish
10-10-2014 06:40 AM
Thank you Manish for your guidance on this one appreciate it
Does it matter if the CIPC phone is not an agent phone I mean the contact centre agent.
Do we need to register the CIPC phone on the UCCS desktop and enable recording if I am using UCCX for recording on demand. Or if I use a different recording server and I am coming through VPN do I need to do anything else to make sure voice traffic recording are done
Thank you again
Abdul
10-15-2014 03:19 AM
If your user/phone is not a UCCX agent do you have another call recording product you are planning to use?
As you said this user comes in over VPN, are you looking to record there internal calls to other extension numbers? Or just PSTN calls? Or both?
Matty
10-21-2014 12:37 PM
Hi Matty
Thank you for folliowing up my question
am using QM and Calabrio application to record the calls.
Abdul
