Recording with unity
i am wondering if i can use a call handler to record a welcome prompt.
if yes how can i do it and how can i choose the codec, mono, khz, etc..
and finally where can i find the file that i record it.
Good day
  • IP Telephony
1 ACCEPTED SOLUTION
Re: Recording with unity
the files should be at x:\commserver\stream files
about the codecs maybe this helps:
Changing the Cisco Unity Codecs
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/unity/42/upgrade/guide/ex/ru_075.html
java
if this helps, please rate
www.cisco.com/go/pdi
what you using? unity, CUC, CUE?
also exactly what do you mean?
you want to call in the call handler and record a welcome prompt for a subscriber?
maybe this helps:
Changing Call Handler Greetings through the TUI with Unity 4.0
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_tech_note09186a00801543ef.shtml
java
thanks for your help.
yes it is unity and the link helped a lot.
my question is where this file sits and what codec and other info is there i can change due to requirement.
Good day
java
166
