05-16-2012 02:02 AM - edited 03-16-2019 11:11 AM
Hi Guys,
I have a problem with a BRI connection. On a 2901 VG I have a VIC2-2BRI-NT/TE configured like this:
interface BRI0/0/0
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn bind-l3 ccm-manager service mgcp
isdn static-tei 0
interface BRI0/0/1
no ip address
isdn static-tei 0
voice-port 0/0/0
echo-cancel coverage 64
compand-type a-law
cptone BE
voice-port 0/0/1
compand-type a-law
cptone BE
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.31.1.10
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.31.1.10
ccm-manager config
mgcp
mgcp call-agent 10.31.2.10 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
dial-peer voice 10 pots
translation-profile incoming pstn-in
translation-profile outgoing pstn-out
preference 1
destination-pattern 0T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
progress_ind disconnect enable 8
direct-inward-dial
port 0/0/0
forward-digits all
dial-peer voice 11 pots
preference 1
destination-pattern 1T
direct-inward-dial
port 0/0/0
forward-digits all
dial-peer voice 12 pots
preference 2
direct-inward-dial
port 0/0/1
forward-digits all
dial-peer voice 13 pots
preference 2
direct-inward-dial
port 0/0/1
forward-digits all
dial-peer voice 30 pots
incoming called-number 712399..
direct-inward-dial
port 0/0/0
dial-peer voice 31 pots
preference 1
direct-inward-dial
port 0/0/1
Suddently we had problem on 1 of the 2 BRI connection, when we passed incoming calls we have only 1 ring tone and the call is dropped. In Q931 debug we have the following on BRI 0/0/0:
May 15 10:23:32.309: ISDN BR0/0/0 Q931: RX <- SETUP pd = 8 callref = 0x72
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Exclusive, B1
Calling Party Number i = 0x2183, '476630613'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '71239900'
High Layer Compat i = 0x9181
May 15 10:23:36.337: ISDN BR0/0/0 Q931: RX <- SETUP pd = 8 callref = 0x72
Sending Complete
Standard = CCITT
Channel ID i = 0x89
Exclusive, B1
May 15 10:23:40.517: ISDN BR0/0/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x72
Cause i = 0x82E6333033 - Recovery on timer expiry
Progress Ind i = 0x8288 - In-band info or appropriate now available
May 15 10:23:40.517: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xF2
If I put the cable on BRI 0/0/1 the call succeeds. I check on this forum, and I already found the same answer about the timer. But here, both interfaces are configured in the same way, so what is your advice?
Hervé Jacquemin
05-16-2012 02:41 AM
Since you are using MGCP, whaever you configuire on router doesn't matter.
MGCP for BRI works poorly, you should use H.323 or SIP instead.
05-16-2012 03:00 AM
Hi Paolo,
I read many times on that forum MGCP "sucks" for BRI, but I'm allowed to change the configuration.
What is really strange, it was working and fine, and suddenly we had the problem.
Is it possible the case is a hardware problem ?
05-16-2012 05:31 AM
Try reloading router. That is also a good occasion to update IOS.
