Community Member
Recreating Subscription fails after Deleting Failed subscription
Subscription failed for a subscriber in my cluster, I then deleted the subscription according to cisco documentation "Reestablishing a Broken CallManager Cluster SQL
Subscription with Cisco CallManager
Document ID: 46100"..
However, when I try to recreate the subscription, i get the error "server is not registered with Publisher, publisher does not allow anonymous connection, contact publisher administrator for anonymous connection"...
What should I do? I have already deleted the failed subscription......CCM 4.1(3)
Hall of Fame Super Red
Re: Recreating Subscription fails after Deleting Failed subscrip
Hi Okanlawon,
Can you try this method;
Using DBLHelper to Reestablish a Broken Cisco CallManager Cluster SQL Subscription
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/products_tech_note09186a00801e7ddf.shtml
Hope this helps!
Rob
Community Member
Rob,
I am so happy you responded. You are the MAN in this forum. I have read a little about you on the internet..I am proud of what yoiu have achieved in your career..I want to be better than you!!! So want to ask for a favour..to be your friend...I work in the UK with a cisco gold partner nscglobal. my email is deji.okanlawon@nscglobal.com..If I can have your contacts it will be great!!!
Back to the issue: The subscription has been deleted!!! WILL DBLhelper recreate the deleted subscription?
Hi Okanlawon,
Thank you for your very kind words :) I will fire you off an email when I get back to work so we can correspond. My advice for this issue would be to open a TAC Case. There are likely to be some registry changes required here that they will be able to help you with.
We will talk soon, Good luck!
Rob
Community Member
I will expect your email...!!!! Looking forward to it!!!
Gold
For this to work, you need to right click on SQL Server Group|New Server Registration. Go through the Wizard and add the Subscriber SQL Server to this list. Also, do the same for the Publisher. Currently your Publisher server should be listed as "local". You need to remove this local and then add the Publisher. Once this is done, you should be able to get through with the Manual steps to recreate SQL Subscription.
Also, if your not to comfortable playing with SQL, you should open a TAC Case and have a TAC Engineer do it for you.
Hope this helps
VIP Super Bronze
Thanks for this. The only problem I have after removing the local from the publisher, register it using its real name, it tells me that the SUbcriber is not registerd to the Publisher hence cant subscribe to the subscription from the publisher...
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Community Member
On the Publisher/SQL Enterprise Manager/Publisher Database/Publications/Configure Publishing, Subscribing and Distribution/Subscribers/check the subscriber servers host name to enable it to subscribe to the Publishers publication.
189
