Redirect a call to a external number
we have a UCME:
CCME#show telephony-service
CONFIG (Version=8.6)
Version 8.6
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
We have a customer that want to redirect a phone to a external number. We have told that use the redirect feature that
the phone has. The issue is that we the redirect call goes out use a random number of our E1 ISDN. We want that
use the same number that the customer uses when they calls from the IP phone. Is it possible?.
Here is the configuration:
ephone-dn  24  dual-line
number 21601 no-reg both
label NT Gerencia
description 21601
name NT Gerencia
corlist incoming dn-llamadasNT
hold-alert 30 originator
ephone-dn  25  dual-line
number 21602 no-reg both
label NT DirTecnica
description 21602
name NT DirTecnica
ephone-hunt 5 sequential
pilot 21600
list 21601, 21602
timeout 9, 9
no-reg pilot
dial-peer cor list dn-llamadasNT
member INTERNO
member NT
dial-peer cor list llamadasNT
member NT
voice translation-rule 13
rule 1 /.*/ /968308790/
voice translation-rule 14
rule 1 /968308790/ /21600/
dial-peer voice 7 pots
corlist outgoing llamadasNT
description PRIMARIO E1 NT
translation-profile incoming NT_in
translation-profile outgoing NT_out
destination-pattern 0T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
incoming called-number 968308790
port 0/0/0:15
voice translation-profile NT_in
translate called 14
voice translation-profile NT_out
translate calling 13
VIP Super Bronze
This is happenin bcause the calling number poresented to your Telco is not part of your allocated DDI range, so the telco is replacing that with their own generic CLI..
Try this ,, and see if it works
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
