Redirect An Outside Call To A Different VM Afterhours Question
Hi all,
Just wondering if this would be possible. Here is the scenario that our GM would like to happen.
We would have a 1-800-XXX-XXXX number be redirected to our General number 123-456-789 that Reception would answer during the daytime when the office is open but as soon as they log off from Attendant Console when the office is close, whomever calls from this 1-800 number would be redirected to another Users voice mail inbox instead of the reception general voice mail inbox.
Any alternate suggestions are also welcomed.
We are currently running CUCM 7.1.3 and CUNC 7.1.3
J
hi,
Use Time of the day routing on callmanager....
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmsys/a03tod.html#wpxref46259
Hope this helps!
Karthik
Re: Redirect An Outside Call To A Different VM Afterhours Questi
The way I read this article about time of day is that once you are past the certain time you configured users will get a fast busy signal.
IE> Time of Day is configured on a Partition to be Monday to Friday from 08:00 – 17:00. USER B is part of the Time of day Partion.
UserA calls UserB within this time frame is ok but if UserA calls UserB after the 17:00 then they would get a fast busy. This would be no good for us as I would like UserA to be redirected to a VoicMail.
Are you able to confirm?
Julien Franche
Systems Administrator / Ottawa
Tél./Tel. 613-786-0124
gowlings.com <>
No, TOD is exactly what you need to reroute the calls as you wish.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thanks, I’ll try configuring this
Julien Franche
gowlings.com <>
295
