Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Redirect calls to a local phone if Trunk SIP fails
I have a CME with an operator phone (9376).
Extern calls must not contact operator directly, so I use following rule to translate called number, and send call to SIP trunk (Unity Connection):
dial-peer voice 10 pots
trunkgroup Trunk_BRI
description ### Appels entrants - RTC ###
translation-profile incoming Appels_Entrants_RTC
incoming called-number .
direct-inward-dial
voice translation-profile Appels_Entrants_RTC
translate calling 10
translate called 11
voice translation-rule 10
rule 1 /^/ /00/
voice translation-rule 11
rule 1 /^9376/ /9076/
Call goes on SIP trunk by this way :
description ### Appels sortants - Trunk SIP ###
preference 1
destination-pattern [2,9]...
session protocol sipv2
session target sip-server
dtmf-relay sip-notify
codec g711ulaw
no vad
But if the SIP trunk fails, I want make possible for extern calls to contact directly operator. So I change sip-ua timers and do the following translation with preference 2:
dial-peer voice 102 voip
description ### Appels sortants - Trunk SIP - HS ###
translation-profile outgoing Keep_Std_Local
preference 2
session target ipv4:10.65.33.62
codec g711ulaw
no vad
IP address is CME itself, and rule translate number previously translated in its original extension:
voice translation-profile Keep_Std_Local
translate called 21
voice translation-rule 21
rule 1 /^9076/ /9376/
I think it may exists something less complicated, can you help me ?
Clement
1 ACCEPTED SOLUTION
VIP Super Bronze
Clement,
Your idea is good and I would have done it the same way. I am not sure you have too many options. Another alternative is to change the opeators internal extension to something other than 9376. Eg 9300.
With this approach when a call comes in as 9376, you send it directly to the sip trunk without any xlation, when the sip trunk fails, you then xlate it to 9300..With this you only have one xlation.
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Clement,
I agree, but because extension is in use, I can't change it without changing all employees behaviour!
So I keep it!
174
