03-05-2008 05:50 AM - edited 03-15-2019 09:14 AM
Hello
Is it possible to force outgoing calls to use specific voice-port ?
For example: I have two pools: 1.. and
2.. and 3 voice-ports 0/0/0, 0/0/1 and 0/1/0.
A would like pool 1.. to use always first free voise-port (it is default) but pool 2.. first try to use voice-port 0/1/0 and then if it will be busy use remaining voice-ports.
thanks in advance
Solved! Go to Solution.
03-05-2008 06:20 AM
This can be done with trunk command and trunk groups. It's a bit complicated, so bear with me:
voice-port 0/0/0
trunk-group first
voice-port 0/0/1
trunk-group first
voice-port 0/1/0
trunk-group second
dial-peer voice 10 pots
desc this for use by pool 1
destination-pattern 9...T
trunkgroup first 1
trunkgroup second 3
dial-peer voice 80 pots
desc this for use by pool 2
destination-pattern 89...T
trunkgroup second 1
trunkgroup first 3
ephone-dn-template 1
trunk 8
ephone-dn xx dual-line
! this is a pool2 ephone for external calls
Note now, the trunk command always prepend the digit 8 so that DP 80 is selected. But since the digits 8 is prepended for internal calls too, either you configure a trasnaltion profile to remove it, or configure an additional ephone-dn to make external calls, and place that on a separate button form dns in pool 2.
03-05-2008 06:20 AM
voice-port 0/0/0
trunk-group first
voice-port 0/0/1
trunk-group first
voice-port 0/1/0
trunk-group second
trunkgroup first 1
trunkgroup second 3
trunkgroup second 1
trunkgroup first 3
trunk 8
