Redirecting Party Transformation CSS
Hello
I have UCM version 8.6
I'd like to know how to use the
Redirecting Party Transformation CSS properly
I have it configured at the gateway leve and Device pool level
my CSS has only 1 Partition
and i'm using a called party transformation pattern, however when i test it i see the redirect number on the debug isdn q931 however it's only the 4 digit extension
coul you guys let me know how to use this setting properly and point me on the right direction or point me to the proper documentation
thanks
Everyone's tags (4)
Re: Redirecting Party Transformation CSS
debug isdn q931 will only show what comes in over the ISDN trunk. It won't show the results of any subsequent translation patterns.
GTG
Please rate all helpful posts.
it also shows what goes out and i can see a redirect if a users has his extension with a CFA to a cell phone. however the redirect only shows the 4 digit extension. i need to use the redirecting party transformation CSS to globalize the number. i used the called party transformation pattern but it doesn't work or i am configuring it wrong
Did you ever figure this out? I'm having the same issue with getting the redirecting transformation CSS working.
indeed I did,
you have to use the calling party transformation patterns for this, create a unique partition and CSS assignt it on the redirecting transformation CSS, however in order to get it to work if you have a VM profile with any type of wildcare it will case this not to work so you'll have to remove any wildcards to get it to work
Ahh the voicemail profile must be the reason because i have XXXX in there for the mask.
Thanks!
take it out for testing if you can. reset the phone and try it again. it should work
2169
