Redirection question
I am trying to setup for allowing outside callers to dial 0 to be redirected to reception extension when the user get voicemail. If anybody has any idea how to di it.
Thanks.
Green
Re: Redirection question
If using Unity it should be in the caller input for subscribers, you send it to Operator
I am using Unity 5. Do I have to select as alternate contact number and also configure on each subscriber for sending to operator extension?
112
