09-13-2014 04:27 AM - edited 03-17-2019 12:09 AM
i am looking for configuration example with 2 cisco Voice gateway each with 1 E1 Line connected to PSTN Provider to achieve high availability
09-13-2014 06:17 AM
There is nothing unique about the GW configuration to make them redundant, they have to have matching configuration as all control is done on the call server i.e CUCM. If using SIP for example you would have matching dial-peers on each GW and CUCM would route calls to redundant GW when needed.
Chris
09-13-2014 06:38 AM
Hi Chriss
thanks for your reply
we have H323 , configured but i m looking for configuration example
thanks
09-13-2014 09:40 AM
GW configuration or CUCM configuration?
There is nothing to the redundant GW that you would need beyond your existing GW configuration. If you are concerned about your existing config post it and we can provide feedback.
On CUCM side simply put both GWs into the same Route Group, or build new Route group pointing to the GW and add it to the existing Route List as second route group.
Chris
09-13-2014 12:53 PM
can i load sharing the inbound and outbound call over these 2 E1s?
thanks
09-13-2014 01:07 PM
Sure, just make sure the carrier puts them in the same trunk group for inbound redundancy, outbound is all in your control.
09-13-2014 09:42 AM
just configure second router as first
ask provider to send the same inbound calls to second E1 if first fails
on CUCM make second gateway like first and route pattern like first
09-15-2014 10:43 AM
As suggested by others, inbound redundancy (Load balancing) should be done by the service provider, So they need to need to be from the same service provider (part of the same trunk).
Outbound is to add both the gateways in the RG and using circular algorithm.
Praveen.
10-04-2016 08:15 AM
Thanks for this question and solved my query.
regards,
Ritesh Desai.
