Redundant VOIP dial peers on H323 gateways
jecker
Hi, I have a CM 5.1 system with 2 CM's in the cluster. I have 22 voice gateways all configured as H323. I have the following dial peers configured in some variation for incoming calls on each gateway:
dial-peer voice 44 voip
preference 1
destination-pattern 3205
voice-class codec 1
session target ipv4:10.100.1.5
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 45 voip
preference 2
voice-class codec 1
session target ipv4:10.100.2.5
no vad
10.100.1.5 is my publisher and 10.100.2.5 is my subscriber. Everything works just fine in this configuration when all my servers are up.
The problem: My publisher went down the other day (10.100.1.5) and all incoming calls got a busy signal. All the phones were registered and could make outgoing calls just fine.
My Question: Do I have this backup dial peer for the subscriber configured correctly? Is there something in CM I need to enable for this backup dial peer to work properly? For whatever reason in this configuration calls would not get forwarded to my subscriber.
Thanks for your help.
Adrian Saavedra
Level 7
Level 7
Which is the order of codec preference in your voice-class codec? How is configured your cluster?
-- Adrián.
try configuring this timers
Configurable Timers in H.225
http://www.cisco.com/en/US/partner/docs/ios/12_1t/12_1t2/feature/guide/dtcfgtim.html
javalenc
java
if this helps, please rate
