Redundant VOIP
Hello Geeks
I have a requirement to connect two offices in same company  with 60  users each through a t1 line to support internet access /file server and  VOIP. network should be redundant (24*7 ) operations similar to a call  center . should have VPN access and VLANS.  prefer cisco devices
If t1 line or a router fails there should be automatic failover method
Cheers
Everyone's tags (2)
Blue
Redundant VOIP
I think using PPP multilink can help you in t1 failure. And you can use CME redundancy in case of router fail.
Ronak Patel
Rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Redundant VOIP
Hi patel
Thanx
Can you breifly explain cisco devices need to install in two offices ?  what are the  WAN connections need for redundancy in addition to T1 line?  ?( do i need hsrp/vrrp) what is the best cisco device including VPN and VOIP ? what about firewall and VLAN ?
Sorry that my VOIP experiance is little.
Thank you very much
Blue
Redundant VOIP
You can use two two Cisco ISR router at each site, they are good for VOIP design.  I think when you terminate your WAN on both the routers in the site, The WAn redundany will be taken care by routing protocol. And voip redundancy will be taken care by CME configuration.
Ronak patel
Rate all helpful posts by clicking stars below the answer.
Redundant VOIP
ok thanx since this  a point to point connection static routing can be used i suupoose ?   what about the firewall and VLAN setup ?    Also if this T1 line fails what is the back up connection ? will this create a single point of failure?     Thanx
556
