Community Member
Reduntant TFTP configuration in DHCP Scope
I want to configure redundant TFTP config for IP Phones.But on the CCM/DHCP server, how can add two TFTP entries in the same DHCP scope.
It allows me only to modify the TFTP address in the scope but not add another.
Can somebosy advise how this would be done in same DHCP scope, so that the IP Phone get two TFTP entries on them.
1 REPLY
Silver
Re: Reduntant TFTP configuration in DHCP Scope
Hi, you can configure the second TFTP server in option 150 in the DHCP scope, with this option you can add more than one IP address. Take a look at the next url to see how to do it:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00800942f4.shtml
Hope this helps, if so pls rate post
330
