Reestablishing a Broken CallManager Cluster SQL
Hi all!, I am having the common problem when you can't do a "forward all calls".
I am nearly sure that it is a replication problem. I run the DblHelper but it seems to be all right.
Next I tried to apply the procedure to "Reestablish a broken Callmanager Cluster SQL". but I get the following error after I enter the sa password:
Login failed for user 'sa'. Reason: Not associated with a trusted SQL Server connection.
I choose in that step to do Sql Server and windows authentication, not Windows only.
Any idea?
Re: Reestablishing a Broken CallManager Cluster SQL
if running CUCM 4.x you need to use only windows authentication
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hi Java!... yes, we are talking about CM4.1(3)
I was using the procedure written for CM3.x
This procedure claims to work also for CM4.x and specify windows & sql authentication... That's why I was trying this kind of authentication. I will try windows only.
Thanks!
Which version are you using .If it 4.x you can use republish database under the DB helper
In 3.x based on configuration while CCM installed ,You can try with windows authentication only
-Ranjan
Hi Ranjan,
We are running CCM 4.1(3).
I tried using DBLhelper, but it didn't work.
I also tried to follow the procedure to republish working directly with the enterprise manager, and it specifies to use sql authentication. I will try using windows only.
At this time, I am not sure if it is a Sql problem. I register a phone directly to the publisher, and I can't do a forward all.
I restart the server many times. It very strange.
Thank for your help.
Reestablishing a Broken CallManager Cluster SQL Subscription with Cisco CallManager
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801d11a6.shtml
Check Password Synchronization with the Admin Utility in the Cisco CallManager Cluster
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080557ba5.shtml
java
java
Hi again Java!, the process to "reestablish a broken callmanager..." is the same that I've used. This paper specifies to use "the Sql server login information that was assigned to me...[Sql Server Authentication]"
Do you think that it will be ok to use windows authentication instead of Sql Server Authentication?
I've checked password synch using the admin utility, and everything seems to be ok.
Thanks for your help!
yes, any version 4.x uses only windows authentication, 3.x did used the mixed authentication.
java
java
291
