reg partitions
hi,
2 phones in same lan call internally it will check css or it directly check matiching DN ?
bcoz phone1 : 500100 having partition : pt-global-line  and  phone2 : 500101  partition : pt-global-line
If phone1 dials 101 call gets to phone2 , translation pattern : 1XX partition : pt-global-tr  called party mask : 100XXX
For css of the phones : css-global-line , which dont have partition : pt-global-tr ( which used for translation pattern)  , i wonder how call is passing to phone2 as it doesnot have partiton pt-global-tr
now my question is how call is maturing
Kindly help me on this
Thanks in advance
karthik
2 ACCEPTED SOLUTIONS
reg partitions
You ALWAYS check CSS no matter who you're calling, you reach the other end via the TP, he's the middle man for the call as you don't dial 500101, you dial 101.
I recommend you to read the dial plan chapter from the SRND to fully understand CUCMs routing logic
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Green
reg partitions
karthik
The phone will look up the CSS on the line 1st
Then the CSS on the actual phone next.
Their must be a 3 to 6 digit tranlation somewhere or you would need to dail the full 6 digits between the lines.
Alex
Regards, Alex. Please rate useful posts.
Green
Re: reg partitions
Look at the dependancy records for Partition
pt-global-line
Does this have a 3 to 6 digit translation associated probably starting like 1XX
Which is translating 1xx to 5001xx
Alex
reg partitions
hi,
i have verified dependeny records nothing matches with translation pattern , i have verified all translation pattern , no partition involves in css which is placed in phone1 but how call was maturing , as it needs to match the partition of translation pattern for taking effect
please help me on this
thanks
karthik
reg partitions
java
java
Green
reg partitions
karthik
Alex
reg partitions
Try with DNA, it will tell you what you're matching
java
java
reg partitions
Hi alex,
Thanks i was missing small point here
268
