Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Regarding IP Phones changes not getting reflected in CCM 4.1
We are having CCM 4.1 with publisher-subscriber installed.
Sometimes we face one problem of phones updates not getting reflected.
For example if if we change phone number of any registered IP Phone
it will reflect in CCM4.1 but we are not able to dial old or new phone number.
We need to take reboot in such cases.
Please guide to resolve issue.
Vaishali
Re: Regarding IP Phones changes not getting reflected in CCM 4.1
This sounds like a replication issue.  You should use DBHelper to verify the health of replication between the Pub and the Sub (the next time this occurs) and also look at SQL to see if it agrees.  When you reboot, you are fixing the issue by likely doing one of two things:
1) Reboot reinitializes replication which clears the issue OR
2) Reboot clears up a value that is cached in the memory of the system (not uncommon in my experience with the 4x Windows-based version of CCM)
Hailey
Just to add something, make sure your host and lmhost files are correctly populated to avoid DB sync issues.
You can also look at the replication tasks in SQL to make sure they're running properly.
Othewise you might need to recreate the replication agreement.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Yes we found replication agent is stopped in SQL Manager whenever we face such problems
We start this agent and replication starts but problem still persists.
Can u pls guide how to recreate replication?
Vaishali
Link is here: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/trouble/4_1_3/tb413ch4.html
Go to the section titled:
Subscriber Stops Replicating  Data From the Publisher
All the steps are outlined there.
Hailey
Please rate helpful posts!
169
