Regarding PRI call
Sushant Kaliraj
I have configured PRI link  in cisco voice router. When i get incomming SIP call on this router with outgoing on POT dial-peer. If the incomming SIP no. starts with "+" sign than the same "+" sign is forwarded on POT dial-peer. I came to know that PRI links or TDM links does not understand "+" sign. So, I guess POT dial-peer should have to remove "+" sign from calling no. But it is not doing so. Am i missing some configuration here? Or any special command for this purpose?
If voice translation rule only the solution?
paolo bevilacqua
Wrong forum, post in "IP telephony". You can move your post using the actions panel on the right.
