region config 6.0
Hi Guys, In call manager 6.0 i have in region configuration a possibility to select in audio codec following option,
typebandwidth.BANDWIDTH_56
typebandwidth.BANDWIDTH_729
typebandwidth.BANDWIDTH_722
typebandwidth.BANDWIDTH_13k
typebandwidth.BANDWIDTH_728
typebandwidth.BANDWIDTH_1M
typebandwidth.BANDWIDTH_256
typebandwidth.BANDWIDTH_Default
typebandwidth.BANDWIDTH_Keep_Current
Please do you know how correspond G711 ??
There is a table that describe this ?
Any info is very appreciate.
Massimo
1 REPLY
Re: region config 6.0
it's the 1st one
BANDWIDTH_56
you might be hitting
CSCsk49799 "Menu
are displayed strange on CCM6 when using other lang IE"
java
if this helps, please rate
www.cisco.com/go/pdi
106
