Region config
I have a scenario where in CCM 2 regions are configured. Region A has defined G.711 as the codec to be used when a call is made to region B over WAN. Problem is, Region B has defined G.729 as the codec while calling region A.
What will be the result when 2 regions try to call each other?
Re: Region config
in cant be like this because
when u define the regins
u have the otion of codec within the regin
and other option between this regin and other regins
once u set for example from A to B
it will already considered from B to A the same!!
if helpful Rate
Re: Region config
Marwan,
Ok, that makes sense.
Ashok.
162
