Register 887VA-V's FXS as SCCP to CUCM 9.1
Hi all,
i don't know if it is so obvious but i really can't find a solution!
And i can't find enough discussions so that means that i am completely wrong or nobody has tried it before.
I can see that my CUCM 9.1 offers 887VA-V subscription as SCCP gateway subscription.
Also, it offers a module VWIC-SLOT and then ports 0/0/0 through 0/0/3.
Therefore, if i enter the last 10digits of my 887s SCCP source interface mac-address, it creates a Device: AN1234567890000 through AN1234567890003
BUT,
my 887's config, which has fxs port 3 to 6 produces devices with names:
AN1234567890080 to AN1234567890083!!
What am i doing wrong.
Please advise:
IOS:c880voice-universalk9-mz.151-4.M4.bin
CUCM: 9.1.2(X)
Everyone's tags (1)
1 ACCEPTED SOLUTION
VIP Purple
I was aware of the same but I
I was aware of the same but I though of sharing so that if u could get some clue.
If the problem is there, please open the case and share findings.
regds,
aman
Hi.Can you please share the
Hi.
Can you please share the output of a show voice port summary?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,here is the output
Hi Carlo,
here is the output:
vgw-r1#show voice port summary
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
1               1   bri-voice   up    dorm none     none     y
1               2   bri-voice   up    dorm none     none     y
2               1   bri-voice   up    dorm none     none     y
2               2   bri-voice   up    dorm none     none     y
3               --  fxs-ls      up    dorm on-hook  idle     y
4               --  fxs-ls      up    dorm on-hook  idle     y
5               --  fxs-ls      up    dorm on-hook  idle     y
6               --  fxs-ls      up    dorm on-hook  idle     y
50/0/1          1      efxs     up    up   on-hook  idle     y
50/0/2          1      efxs     up    up   on-hook  idle     y
50/0/3          1      efxs     up    up   on-hook  idle     y
50/0/4          1      efxs     up    up   on-hook  idle     y
50/0/5          1      efxs     up    up   on-hook  idle     y
50/0/6          1      efxs     up    up   on-hook  idle     y
50/0/7          1      efxs     up    up   on-hook  idle     y
50/0/8          1      efxs     up    up   on-hook  idle     y
50/0/9          1      efxs     up    up   on-hook  idle     y
50/0/10         1      efxs     up    up   on-hook  idle     y
PWR FAILOVER PORT        PSTN FAILOVER PORT
VIP Purple
Not sure, if this biug is
Not sure, if this biug is somewhat related to your issue.
CCMGW page7.1 says fxs 0/0/0-3 port instead of GW voice-port 0-3
CSCta03837
Hi Aman,this bug refers to
Hi Aman,
this bug refers to MGCP configuration.
For SCCP, i choose the same about subunit but it CUCM creates 4 ports named:
0/0/0, 0/0/01, 0/0/2 and 0/0/3.
 This means that the last 3 digits of the SCCP device that CUCM creates (and cannot be altered) are 000 to 003.
But, as i told you in my previous email, port 3 in 887VA-V is created with 080 suffix (and port with 083 suffix)!
vgw-r1#show stcapp device summary
Total Devices:           2
Total Calls in Progress: 0
Total Call Legs in Use:  0
Port       Device          Device   Call          Dev     Directory   Dev
Identifier Name            State    State         Type    Number      Cntl
0/1/0      AN542DEA5DF6080 OOS      UNREGISTERED  ALG                 UNKN
0/1/3      AN542DEA5DF6083 OOS      UNREGISTERED  ALG                 UNKN
                                           IN       OUT
vgw-r1#
Cheers,
Anthony
VIP Purple
regds,
aman
VIP Purple
thanks for updates. can u
thanks for updates.
can u please share output of command show stcapp device summary and snapdhot from CUCM?
regds,
aman
Hi all,it is a known bug
Hi all,
it is a known bug with id CSCul59124 similar to the one regarding MGCP registration.
DO NOT add 887VA-V as 887VA-V but as 881/886/887.
Then, add FXS in subunit 1 and not 0.
This action, creates an analog device with suffix in the range 080-083.
Anthony
133
