Register IP Phone
I need to know how to register a IP Phone on the call manager express, I need to do something on the IP Phone?
My IP Phone 7906 is configured with static IP, TFTP server is the ip address of the Call Manager, but the ip phone tell 'Registration Rejected: No conf'
I have used QCT software to start a quick conf on my Call Manager but I don't arrive to register ip phone on my call manager.
1 ACCEPTED SOLUTION
Re: Register IP Phone
ephone 1
mac 0022.90BC.20A8
Bronze
Hi, check this guide for system-level parameters and ip phones configuracion.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesystm.html
Hope this help
David
A very important command is create cnf-files. Without that the CME will not create xml files to hand out to the phone when it attempts to register. You also need to ensure that any file that you tell the router it has with the tftp-server flash: command is actually in the flash of the router. If you are unable to get your phone to register debug tftp events is a good debug so see what the phone is requesting and where it is failing. A useful show command is show telephony-service tftp-bindings. This will show all files that are available to a phone using tftp.
2600XM_CME#sh run
Building configuration…
Current configuration : 1240 bytes
version 12.4
hostname 2600XM_CME
boot-start-marker
boot-end-marker
enable secret 5 $1$ZYdg$wAiT47.cKoEBUitfgZgnR/
no aaa new-model
resource policy
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
ip dhcp excluded-address 172.16.1.1 172.16.1.10
ip dhcp pool 172
network 172.16.1.0 255.255.255.0
default-router 172.16.1.1
domain-name cisco.com
option 150 ip 172.16.1.10
no ip domain lookup
interface FastEthernet0/0
ip address 172.16.1.10 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
no dce-terminal-timing-enable
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip http server
no ip http secure-server
tftp-server flash:P00307020200.sbn
tftp-server flash:P00307020200.bin
tftp-server flash:P00307020200.loads
tftp-server flash:P00307020200.sb2
control-plane
telephony-service
load 7960-7940 P00307020200
max-ephones 10
max-dn 10
ip source-address 172.16.1.10 port 2000
create cnf-files
ephone-dn 1
number 1000
ephone 1
mac-address 0011.aaaa.8500
button 1:1
line con 0
line aux 0
line vty 0 4
password cisco
login
end
Try these two things:
telephony-service
auto-reg-ephone
As well, make sure you have something very similar to this configured:
ephone-dn x dual
number x
ephone x
mac xxxx.xxxx.xxxx
type 7906
button 1:x
Try both of these things and I think it will resolve your problem.
Always the same problem, start > configuring IP > resetting
See the debug
CallManager#
Dec 19 18:50:42.462: TFTP: Looking for CTLSEP002290BC20A8.tlv
Dec 19 18:50:42.538: TFTP: Looking for SEP002290BC20A8.cnf.xml
Dec 19 18:50:42.582: TFTP: Looking for XMLDefault.cnf.xml
Dec 19 18:50:42.582: TFTP: Opened system:/its/XMLDefault.cnf.xml, fd 0, size 1548 for process 237
Dec 19 18:50:42.590: TFTP: Finished system:/its/XMLDefault.cnf.xml, time 00:00:00 for process 237
Dec 19 18:50:48.918: TFTP: Looking for P00307020200.loads
Dec 19 18:51:02.106: TFTP: Looking for CTLSEP002290BC20A8.tlv
Dec 19 18:51:02.178: TFTP: Looking for SEP002290BC20A8.cnf.xml
Dec 19 18:51:02.234: TFTP: Looking for XMLDefault.cnf.xml
Dec 19 18:51:02.234: TFTP: Opened system:/its/XMLDefault.cnf.xml, fd 0, size 1548 for process 237
Dec 19 18:51:02.242: TFTP: Finished system:/its/XMLDefault.cnf.xml, time 00:00:00 for process 237
Dec 19 18:51:03.146: %IPPHONE-6-REG_ALARM: 25: Name=SEP002290BC20A8 Load= SCCP11.8-3-2S Last=Initialized
Dec 19 18:51:04.382: TFTP: Looking for CTLSEP002290BC20A8.tlv
Dec 19 18:51:04.454: TFTP: Looking for SEP002290BC20A8.cnf.xml
Dec 19 18:51:04.534: TFTP: Looking for XMLDefault.cnf.xml
Dec 19 18:51:04.534: TFTP: Opened system:/its/XMLDefault.cnf.xml, fd 0, size 1548 for process 237
Dec 19 18:51:04.538: TFTP: Finished system:/its/XMLDefault.cnf.xml, time 00:00:00 for process 237
Dec 19 18:51:10.998: TFTP: Looking for P00307020200.loads
ephone-dn 5 dual-line
number 100 secondary 4085551000
label 100
description User Name
name CISCO
call-forward busy 600
call-forward noan 600 timeout 15
corlist incoming user900-international
ephone 1
video
mac-address 0000.0000.0001
username "100" password 0000
type 7960
button 1:5
pin 0000
ephone 1
mac 0022.90BC.20A8
Hi. Can you tell me where I am trying the two things? I am not all that tech savy.
433
