Community Member
Register Iphone
How i do register iphone in call manager 6 ?
Everyone's tags (2)
Register Iphone
With CUCM 6 you won't be able to use the Cisco Jabber client. So, you will need to look at a 3rd party SIP softphone. I have tested a few softphones on Android and iOS. However, I have not tested integration with CUCM 6. Getting a registration is totally possible and the method should be the same. I just can't comment on stability.
See the following link for a variety of samples:
http://www.netcraftsmen.net/resources/blogs/tags/3rd-Party-SIP/
If you can't use Jabber then I would look at CounterPath's Bria as a viable alternative. Make sure you do proper testing as I have not tested with CUCM 6.x.
HTH.
Bill
blog: http://ucguerrilla.com
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Hall of Fame Super Silver
Re: Register Iphone
Is upgrading CUCM an option for you?
Then you can take advantage of native Cisco Jabber app.
Chris
313
