Register VG224 with Cisco Callmanager
I would like to know if someone has any idea on how I can get my fax gateway to be registered with my Cisco call manager.  I would also like to know how I can get the fax gate to get an IP address from the call manager.  Please let me know what information I can provide and THANK YOU in advance.
Config file below.
------------------ show version ------------------
Cisco IOS Software, vg224 Software (vg224-I6S-M), Version 12.4(9)T7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 10-Jan-08 21:17 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T7, RELEASE SOFTWARE (fc1)
ky-fax-gateway uptime is 40 minutes
System image file is "slot0:vg224-i6s-mz.124-9.T7.bin"
Cisco VG224 (R527x) processor (revision 4.1) with 119808K/11264K bytes of memory.
Processor board ID FHK1306F1ZK
R527x CPU at 225MHz, Implementation 40, Rev 3.1
1 On-Board Twenty-Four FXS Analog Voice Module V2.1
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
63K bytes of non-volatile configuration memory.
System fpga version is 250027
System readonly fpga version is 250027
Option for system fpga is 'system'.
62720K bytes of ATA Slot0 CompactFlash (Read/Write)
------------------ show running-config ------------------
Building configuration...
Current configuration : 1716 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
no service dhcp
hostname ky-fax-gateway
boot-start-marker
boot-end-marker
enable secret 5 <removed>
enable password 7 <removed>
no aaa new-model
resource policy
no ip source-route
no ip routing
no ip gratuitous-arps
ip tftp source-interface FastEthernet0/0
no ip bootp server
trunk group  summary
voice-card 0
username admin privilege 15 password 7 <removed>
 ip address dhcp hostname V-KYGW1.ad.WS.com
 no ip route-cache
 duplex full
 speed auto
 vlan-id dot1q 10
  exit-vlan-config
 h323-gateway voip interface
interface FastEthernet0/1
 no ip address
 no ip route-cache
 shutdown
 duplex half
 speed auto
 vlan-id dot1q 10
  exit-vlan-config
ip default-gateway 172.20.160.1
ip default-network 172.20.160.10
ip http server
dialer-list 1 protocol ip permit
snmp-server community <removed> RO
no cdp run
tftp-server 172.20.160.10
control-plane
voice-port 2/0
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
dial-peer search type voice data
line con 0
 login local
line aux 0
line vty 0 4
 login
end
Hall of Fame Super Silver
There are plenty of documents on Cisco website and this forum on how to configure VG224, first of you need to decide what protocol you want to use to control your analog devices, as there are pros and cons to each depending on the type of devices you have, i.e. analog phones, faxes, modems, etc you can use SCCP, MGCP, H323 or SIP protocols.
If you feel like this is over your head I suggest you hire local Cisco implementation partner to assist with it.
HTH,
Chris
I would like to use SCCP and have my all in once network printers get an IP from the call manager and be able to use the fax services.
Not sure if I am explaing it correctly.
940
