Community Member
Register VG224 with CME
The ephones for VG224 don't get registered with SCCP on the gateway. I've already done the ATAs and the IP phones, and they seem working fine.
I'm having some unluck with the VG224. I beleive the problem is from the VG224 itself. The config of this device on the CME is as follow:
ephone-dn 13
number 214
name CCO
ephone 10
mac-address xxxx.xxxx.xxxx
type anl
button 1:13
For the mac address i followed the instruction in the manual for how to set up the mac for each phone on VG224.
When i do show ephone, it doesn't seem that the phone with that particular mac-address is seeing the ip of the VG224. Any ideas?
Community Member
Re: Register VG224 with CME
Hi!
Please send the VG224's config and the output of "show sccp" command on the VG. This will be very helpful.
Community Member
Here is the VG224 config output:
Building configuration...
Current configuration : 1768 bytes
configuration mode exclusive auto
version 12.4
no service pad
hostname GTS-VG224
boot-start-marker
boot-end-marker
enable secret 5 $1$c2ql$dNq1qHU5s17pHqqYChPMM1
no aaa new-model
resource policy
stcapp ccm-group 1
voice-card 0
interface FastEthernet0/0
ip address 10.1.30.30 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip http server
control-plane
voice-port 2/0
ren 3
disconnect-ack
loss-plan plan4
disc_pi_off
input gain 10
output attenuation 10
playout-delay minimum low
timing digit 53
description cflow1
music-threshold -50
bearer-cap Speech
station-id name CCO
station-id number 262
caller-id enable
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
ccm-manager config server 10.1.30.100
ccm-manager config
ccm-manager sccp local FastEthernet0/0
ccm-manager sccp
sccp ccm 10.1.30.100 identifier 1
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 1 priority 1
dial-peer voice 1 pots
destination-pattern 262
port 2/0
forward-digits all
dial-peer voice 2 pots
line con 0
speed 115200
line aux 0
line vty 0 4
password cisco
login
end
show SCCP:
SCCP Admin State: DOWN
Gateway IP Address: 10.1.30.30, Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.1.30.100, Port Number: 2000
Priority: N/A, Version: 3.1, Identifier: 1
Community Member
version 12.4
no service pad
hostname GTS-VG224
boot-start-marker
boot-end-marker
enable secret xxx
no aaa new-model
resource policy
stcapp ccm-group 1
voice-card 0
ip nat inside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip http server
control-plane
voice-port 2/0
ren 3
disconnect-ack
loss-plan plan4
disc_pi_off
input gain 10
timing digit 53
description cflow1
music-threshold -50
bearer-cap Speech
station-id name CCO
caller-id enable
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
ccm-manager config
ccm-manager sccp
sccp ccm group 1
port 2/0
forward-digits all
line con 0
speed 115200
line aux 0
line vty 0 4
password cisco
login
end
show SCCP:
IP Precedence: 5
Community Member
Hi!
You have almost completed your task.
issue following commands on the VG:
! enables stcapp
stcapp
! to allow phones to use pickup, transfer etc.
stcapp feature access-code
!enables sccp
sccp
!giving our ports to sccp management
port 2/0
service stcapp
port 2/1
service stcapp
After that issue again show sccp command and you will see how your phones are trying to register with CCME
Community Member
I've enabled the stcapp and sccp, and it seems working. The VG is registered with CME.
In the CME i did show ephone; i'm able to see the VG registered from there with a mac-address ae22.17fa.0fff, but the type is still unkown. I tried to do update with "type anl" command and it's still not taking it.
I'm not able to add ephone-dn to the ephone. Any idea how to create ephones on this gateway?
Community Member
Hi!
Try following:
ephone 1
video
username "6808" password 12345
mac-address ae22.17fa.0400
type anl
button 1:17
ephone 2
video
mac-address ae22.17fa.0401
type anl
button 1:17
etc.
The needed mac-addresses you may fing in sh sccp command on the VG.
Community Member
Thanks for the reply..
I have done this, but it's still not working.
I didn't see any mac-address in the sh sccp command on the VG except the AE22.17F4.0FFF
Here is the last 3 ephones as was shown with "sh ephone" command on the CME:
ephone-11 Mac:AE22.17F4.0FFF TCP socket:[13] activeLine:0 REGISTERED in SCCP ver 6
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0
IP:10.1.30.30 38696 unknown 30032 keealive 34 max_line 0
ephone-13 Mac:AE22.17F4.0400 TCP socket:[-1] activeLine:0 UNREGISTERED
IP:0.0.0.0 0 unknown 0 keealive 0 max_line 0
ephone-14 Mac:AE22.17F4.0401 TCP socket:[-1] activeLine:0 UNREGISTERED
ephone-11 was registered automatically after i enabled sccp and stcapp. i entered ephone-13 and ephone 14
Community Member
You need to issue the dial-peer command on the VG for each port, you wich to use in CCME.
Perhaps, at the moment you have just one dial-peer. In my config it looks as follows:
port 2/0
service stcapp
port 2/1
service stcapp
dial-peer voice 24 pots
port 2/23
service stcapp
Community Member
i have issued the dial-peer command for all the port (port2/0-port2/23) in the VG.
Community Member
any idea regarding the VG problem i have?
2231
