registering a CCME in CCM 3.3
I have CCME configured with extensions
I also have CCM 3.3 configured and i want to register the CCME on this CCM and want to make calls from the CCM extensions to the CCME extensions
How should i go about configuring it.
thanks
Narayan
Green
Re: registering a CCME in CCM 3.3
In CCM configure an InterCluster Trunk, non GK controlled and check MTP required box.
In CCME configure a voip dial-peer that point to CCM.
Disable inbound Fast Start in CCM 3.3
Here is more info:
http://www.cisco.com/univercd/cc/td/doc/product/voice/its/cme33/cme33sa/cme33bsc.htm#wp1001000
Thanks for the link.
Is it possible to just have the CCME configured as a gateway for the extensions it is configured with and have a dial peer to point to that gateway.
Will this work.
network diagram attached
Narayan
171
