Registering an IP Phone thru a WAN using CME
Can I do this?
If yes, Can I configure it to use G729?
Regards, Jose
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Registering an IP Phone thru a WAN using CME
Sure. Under ephone, configure g729 and mtp.
can u pls send me MTP part.
thx
jose,
cisco design says not to configure any remote location phone using cme.
But yes techinically you can configure it.No CME phones supports locally g729 codec. so u cannot use it.This is the only reason why i feel cisco doesnt recommends to use phones across.
vishwesh
hi Vishwesh,
can u pls provide some link where cisco is not recommending registeration over the WAN.
we are seriously looking for this.
regards,
K.Vishwesh is incorrect.
You can perfectly deploy remote phones with CCME and Cisco has never recommended against.
From CCME 4.1 Datasheet at:
http://cisco.com/en/US/products/sw/voicesw/ps4625/products_data_sheet0900aecd805e1a1f.html
Remote tele-worker IP phone support
Link to configuration guide for remote phones:
http://cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00807e13a7.html#wp1061320
Also stating that the phones do not support G.729 is oncorrect. To the contrary, all telephones do support it.
190
