Registering generic SIP Phone to UC520
l.buschi
Level 2
Level 2
Hello I need to register a generic SIP phone to my UC500.
I tried the suggested configuration vut doesn't work:
voice register global
mode cme
source-address 192.168.123.2 port 5060
max-dn 4
max-pool 4
authenticate register
hold-alert
create profile sync 0055373705093625
voice register dn  2
number 56
name johnny
no-reg
label Johnny-SIP 56
! voice register pool  2
id mac 0012.3456.7907    <-- this is the mac of my phone
session-transport tcp
number 1 dn 2
username johnny password italy
codec g711ulaw
no vad
on my phone I have the following fields:
SERVER SIP:    address  <-- i put 192.168.123.2
                        port        <-- i put 5060
SERVER REGISTRAR SIP:    address
                                                port                            I tried both living these fileds blank and inserting 192.168.123.2 , 5060
ACCOUNTING MODULE:          username
                                                  password
                                                      auth ID
                                                      timeout
Any suggestion?
TKS
Johnny
in your "voice register dn 2" setting, you use "number 56" which is the extension you wish to use for the SIP phone. For SIP Client to authenticate, you must also use the same number in the "username" section of "pool 2" instead of "johnny", as follows: "username 56 password italy". This will allow the SIP client to register with the CME
