03-02-2007 01:47 PM - edited 03-14-2019 08:17 PM
Hello, I will appreciate help on this one. I am trying to register IP Communicator as SIP phone on CallManager 5.0(4).
I get "Registration Rejected: Error DBConfig" error on the screen. SCCP registration works fine.
Any tips? Thanks.
03-02-2007 02:40 PM
There is no SIP IP Communicator available yet, it is coming sometime this year and I can only guess that the CCM developers thought they would add in the SIP IP Communicator device profile so you wouldn't have to upgrade CCM when it comes out.
There are plenty of other SIP clients that work fine though with CCM 5.04
03-02-2007 02:44 PM
Ok, thanks, I thought so. I am basically trying to get some software IP SIP Phone simulator to test some configurations. Could name some pls?
03-02-2007 03:02 PM
If you are serious, you should purchase something like Abacus for simulation, but is lots of $$
If you are just looking for a SIP softphoine to test, I use the EyeBeam client.
I don't know of any, but there must be some open source sip simulation/load testing code out there too.
03-05-2007 09:54 AM
Hi, folks.
X-Lite is a good option to test SIP softphone.
Tks
03-13-2007 02:41 PM
I downloaded X-Lite and installed it. Now trying to register with CCM 5.0.
When I try to add New Phone, the Phone Type dropdown only gives me Third-party SIP device (basic or advanced). Is this correct or did you use a different Phone Type? Also, what Phone Type in CCM4.1, which doesn't even have 3d-party SIP device options?
And then on the phone configuration page it asks me to enter MAC address. I guess it should be MAC of my PC, right?
