Registering NM-HDA-4FXS with CCM over MGCP
Hello all,
Brought up a remote office this morning with a 2821 router/voice gateway.  The PRI is up and running fine and is registered with remote Callmanager over MGCP.  However, I am trying now to register the NM-HDA-4FXS in the same router, but cannot seem to get it working.  I have it defined in the gateway config in my call manager, but it is not registering.  I suspect that I need to "tell" it it needs to register with the callmanager like I have to do with the T1 controller and resulting serial interface, but I don't see what commands are available to do that for the NM-HDA-4FXS or resulting voice ports.  Does anyone know?
Router is a Cisco 2821, IOS version is 12.4(11)T2.  CCM version is 6.1.3000-1.
Chris
1 ACCEPTED SOLUTION
Re: Registering NM-HDA-4FXS with CCM over MGCP
Chris,
You need to have POTS dial-peers for the analog ports.  This should suffice:
dial-peer voice 100 pots
  port 1/0/1
  service mgcpapp
You can verify with:
sh mgcp end
If you have MGCP CCM config server enabled, if that's working properly, it should have added that for you, with a dial-peer ID of 999something.
ccm config
ccm config server
'sh ccm' will let you know if the config downloading is failing.
-Steve Holl
Chris,
  port 1/0/1
  service mgcpapp
sh mgcp end
ccm config
ccm config server
-Steve Holl
Steven,
Thanks!  The dial-peer is exactly what I needed.  I had the card shutdown when I did the inital MGCP setup and config download, so I suspect that that is why the dial peers didn't get automatically created like they do on my VG224s.
It's working great now.
Chris
166
